Hello all,
I use a all in wonder 9800 card to capture with the provided software (latest version). I capture Hi8 and 8mm tapes in AVI(resolution: 384x315)
I want to use Adobe Premiere PRO to edit my files. But there are no presets for Windows VIdeo files. (Only DV settings)
Thus, I want to make one but It's unclear to me which resolution to use...
The capture files (384x315) seems a bit low...
Should I capture the tapes again with another resolution and then use that same resolution as preset in Premiere ? If so, which resolution is the best ? ( 720x576 or 400x480???.....not I use PAL )
Thanx a lot for your support!
greets
oeps... my bad...
I seem to have posted about the same message under capturing and under editing...
my excuses...
Audio Not Clear in AVI
By abdul_sma in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2010, 09:59 -
What does cable-in-the-clear means ?
By SingSing in forum Video Streaming DownloadingReplies: 1Last Post: 31st Mar 2010, 20:14 -
Why does this video look so clear?
By brassplyer in forum Video Streaming DownloadingReplies: 4Last Post: 16th Jun 2009, 21:42 -
UV vs Clear Glass Filters
By thurnau in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2009, 12:17 -
16bit Audio not Clear :(
By ozab in forum Capturing and VCRReplies: 0Last Post: 31st Jul 2007, 10:51
