Results 1 to 10 of 10
  1. hello
    I have an All in wonder 9800 card. I capture with the Ati multimedia center because I find it's quite easy to use. ( I capture my Hi8 and 8mm tapes)
    I want to use Adobe Premiere Pro to edit my captured Avi Files but when I start the program, there are no presets for Windows Video. there's only DV settings...
    Now I want to make one but I can't get it figured out for the frame size.
    My captured files are all 384x315.
    should I use that ? or should I capture again with another video size and then use that same size for the editing...
    Hope I'm a little clear...
    note I use PAL not NTSC
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    couple of questions -
    is 384x315 a standard size for something, or arbitrary?
    what is your desired output format?
    are you having problems getting Premiere to recognize your footage?
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. no it's just the setting the software seems to capture it to...
    I used the "quarter VGA resolution" : normal resolution recording (with UYVY and 44.100 khz 16 bit sound)
    it's one of the preset of the capture card...
    Premiere uses it fine...
    but if that's not a really desirable resolution, I'm not going to continue my work with it...
    my desired output format.... mhhh either first edit my tapes and then making a VCD or DVD out of them...
    thanx
    greets
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    I would capture at the final output resolution, so if you're going for dvd, cap at dvd resolution, if you're going for vcd, cap at vcd res... or at least a valid resolution for the format (like 1/2 D1 for DVD).
    as far as the templates in Adobe, if you can't make a new one yourself, I'd take whichever one it defaults to - you're going to be exporting out of it anyway to your final file format, so I don't think it's going to mess you up in any way to work in project settings that may not be 100% what you want.
    if you're not having problems opening up your files, I'd do a really small file and render it out and make sure the quality is where you want it.
    - housepig
    Housepig Records
    out now:
    Premiere cannot cap from ATI.
  6. indeed capturing from premiere does some weird things...
    that's why I capture first with the ati software
    and then import the file in premiere.
    I guess I'm going to capture the file again in Dvd resolution.
    If I still plan to burn it on vcd I can still resize right ? (I think resizing to a smaller size is better than resizing to a bigger resolution, right ?)
    Secondly, now that I'm having problems :
    I use pinnacle already and it was quite easy to make scenes out of one big long video file (thus making editing easier)
    this seems to be a bit more difficult in premiere, I always have to cut the whole file to the section I want and for the next scene I need to import the whole file again and cut it again...
    this can't be right, there must be a way to do this better....
    thanx anyway for the replies, now I already have an idea to what resolution to capture.
  7. I don't get it
    the highest I can capture to with the ATi sofware is 704x576
    I can't select 720 x 576
    neither can I 352 x 288
    as I read on lordsmurf his site YUY2 seems better than UYVY but that makes too hugue file for my disc...
  8. Ok I can choose 720 x 576 if I select capturing in MPEG2
    but I read that AVI was better if i need to edit the file a lot.
    so is 704x576 a correct resolution ?
  9. Originally Posted by infected_mushroom
    That is a Valid DVD resolution and some people say it is a better res to use when resizing down to 1/2 D1 (352*576) or VCD (325 * 288) as it is exactly half (or twice!) the size compared to 720*576.
  10. oooh great, ok I'll capture to that resolution then
