Hi,
Just installed the DVR-106. I have not burned any DVD media yet. Question: Should I upgrade the Firmware (1.05) now to avioid future problems? Or stay with the 1.05 FW which came with the drive.
Thanks!!!!!!!
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 19 of 19
The best answer would probably be what version is the latest on Pioneer's website ?
Looking here:
http://www.pioneer.co.uk/uk/support_software.jsp?category=support/software#fdvdwriter
... suggests the latest version is 1.07, so it might be worth upgrading.
The issue of unofficial, hacked firmware is another matter. I don't advocate hacked firmware and it technically voids your warranty, but only you can decide whether or not it's worth tricking the drive into doing something it shouldn't. Then revision numbers are a bit hit or miss as not all firwares are created equal. -
Paul,
I tend not to upgrade until I've run into a problem. So I'm still on 1.05 which has not caused any problems yet. But then again, this has always been the way I do things Also, upgrading supposedly means you cannot go back to any of the previous firmwares which is a bummer (and very odd as to why Pioneer does not allow this).
Cheers,
feeras -
Thanks, I have downloaded the upgrade, but havn't instaled it yet. I'm going to wait for for more replies. My main concern was media compatibility. Having read about the various issues re firmware updates (that writers seem to work better and faster with updated firmware), I thought it best to check with those of you who have experience with the writer.
Paul -
I upgraded to the hacked 107 firmware (just search for "the firmware page"), no problem so far. It's nice being able to burn at 2x using 1x media.
Hi there, I have just bought a 106 writer, and writing is fine, no probs there, the only problem is in reading the image to hard drive. The manual claims that the dvd writer should read at 12x, however, all the dvds I've tried ripping using both SmartRipper and DVD Decrypter both read at around 2.1x... is this a firmware problem?
I know it's not my system as I have a P4 2.4ghz w/ 512 ddr ram.
Thanks is advance for any suggestions. -
No, nothing is wrong with your writer. The A06 only rips DVD video at 2X, unless you use the hacked firmware. I didn't use it so I also avg. around 2.1X when ripping video discs, but much higher on non video DVDs. My buddy used the hacked firmware so he does get much higher rips, but I didn't wanna go that route.
still using original 1.05. I don't upgrade unless it fixes critical bugs. The hacked firmware allows you to burn 1x media at 2x I believe. So far I fed it Fuji 2.4x +R, 2x +RW, TDK (Ritek) 4x -R, DVDPro (Princo) 1x -RW with no problems.
A 5% decrease in burning time is hardly worth taking a chance with 'hacked' firmware!
Originally Posted by videobruce
look the firmware doesnt increase or decrease any burning speeds,it just unlocks the ablility to burn 1speed media at 2speed,and UNLOCKS the prebuilt in ability to rip at up to a max of 12speed.
it also resets the region so its region free,which is always a bonus.
as for updates in the firmware,i believe the updates from 1.05 to 1.07 are compatibility increases,and taking into account of new media etc.im sure also read it resolves some RW flaws as well.
but the firmware at www.rpc1.org,isnt modified in any way,its still 1.07 firmware,just unlocked.
ive never experienced any problems with it,and im not really sure of anyone who has reflashed correctly(disabling antivirus etc)has. -
is there a hacked firmware that will increase the RW write speed?
Boy do I love my avatar! -
I have tried to install the 1.07 hacked from www.rpc1.org, after 2 black screens that say "press any key to continue" I press any key the screen dissapears and nothing happens, any ideas?
you just should be able to run the file it tells you in the read me to run.
i think its upgrade.somethingotother,and the screen tells you that you will have,say,1 drive detected.
flash all drives,and press key to continue.
and thats it,are you sure its not flashed already,or youve ignored one of the screens.
oh,that and your running xp right? -
Yes I have XP and I had the 1.07 from Pioneer already, when I upgrade from pioneer everything went fine and it says 1.07. I don't know if it will upgrade the hack, if it will not, I don't think it can be done, cause I understand That I can't go back to 1.06 or 1.05
Hi. Saw this and thought I'd tack something on the end.
I bought a Pioneer DVD-A06, upgraded to 1.07 before doing anything and then had problems. The drive wouldn't recognise or write to CD-R ot CD-RW. It saw DVD-RW as audio 1.99GB and wouldn't format or write to it.
Luckily I managed to return the unit as faulty and got a replacement.
Unfortunately the new unit (1.05) STILL can't write to CD-R or CD-RW. It recognises them OK now though and can use DVD-RW fine too. I get "Invalid Block Address" right at the start after the caching.
Any ideas?
Not going to 1.07 until I get this sorted!!
Using Nero 6 and Win98se. -
Hi all,
Well, I decided to upgrade to the 1.07 FW (un-hacked version). I downloaded R6FW107.EXE, ran it, and the file created a DVR106 Folder on C:. In that Folder is UPGDVD.EXE. I ran that, but got error message: “Available Target Not Found”.
Are the computer gods telling me not to upgrade, or am I doing something wrong on my end?
I’m happily running W2K, and thus far the Pioneer 106 burns fine with FW 1.05.
Thanks!
Paul -
I wouldnt upgrade...I havent run into any probs with the 105 firm so just try yer luck.
I see that your from chicago, im from near there!Boy do I love my avatar!
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 05:38 -
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 08:24 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 06:02
