Hi,
I just burned an SVCD to DVDR using SVCD2DVD 1.5, and was surprised to see that the video was fine (applied the Pan & Scan fix), but there was no audio.
While unraring the bin/cue files to give it another shot, I messed around with my DVD player settings. In the first Audio menu under the player setup, selecting "MPEG->PCM" from the bottom menu made the sound start working.
For any of you with Pioneer standalones and missing audio on finished DVDs, try to find a similar setting in your player setup and see if that makes a difference.
Thanks,
ray
raygunGuest
raygun: Thanks for the info - I'm sure that will help others.
A required codec is missing-MP4, to fix please read www.copytrans.net
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2011, 12:07 -
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 09:03 -
How to use windows 2000 console (command prompt) to fix missing ntloader
By edong in forum ComputerReplies: 2Last Post: 5th Oct 2008, 23:08 -
Pioneer Players wont play SVCD2DVD Creations...fix?
By alangriffin in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jul 2008, 10:06 -
Very old Pioneer DV-525... surprisingly tolerant!
By kschang in forum DVD & Blu-ray PlayersReplies: 8Last Post: 17th May 2008, 17:03
