hi everyone,
i am trying to capture a clip from my camcorder using virtualdub but it does not work at all. if i use movie maker or studio 8 it works fine.
i noticed that on studio 8 it has an option to set it to "dv" instead of my video card. if i do that, i was able to capture or preview the clips in video 8.
is there an option that i need to set in virtual dub so that i can pick up? thanks!
Results 1 to 13 of 13
tvandang
Well, once you are in the Capture mode, look under Video-->Source, and make sure you have the proper source selected.
Hello. -
yes, that is it but i did do that but there is one default and nothing else to choose from. any suggestion? thanks!
tvandang -
yes, that is what i did with studio 8. with studio 8, it defaulted to my ati all-in-one video card and i couldn't capture it but when i change it to dv option, it works.
is there an option in virtualdub that i can use DV? thanks!tvandang -
No, Virtual Dub does not capture in DV. A lot of us wish it does, though. Have you tried DVIO? It is free, and very easy to use.
Hello. -
thanks buddy! i guess i can use this to capture in avi format and then use virtualdub for its features. thanks again!
tvandang -
I did a search for a problem like mine and I think this is a close enough topic. I tried to capture from dv camera with no luck like tvandang so I went to DVIO. Capture went fine but when I make my avisynth script I get this error when calling up in tmpgenc "Couldn't locate decompressor for fourcc dvsd" and points to my decimate() line. Can anyone help me out please?
Fun in the sun, Oh no my friend, Fun on the sun! -
Tommyknocker, thanks for the reply. I dont believe I have installed any DV codec's, can you suggest a good one?
Go to the Tools section at left, check out the Canopus or the Panasonic ones. I believe they both are free.
Hello. -
Thanks for the reply Tommyknocker, I grabbed both of them and will install on my computer later, one at a time that is! Thanks again!
Hey Tommyknocker, I installed the canopus codec and I still get the same error, couldnt locate decompressor for fourcc dvsd line 13 which ends up being the decimate after counting all the plugin lines. Here is my script if anyone wants to see it,
LegalClip()
Telecide()
Decimate()
unfilter(50,50)
GripCrop(352, 480, overscan=1, source_anamorphic=false)
GripSize(resizer="BicubicResize")
STMedianFilter(8, 32, 0, 0, 8, 32)
FaeryDust() # or PixieDust()
mergechroma(blur(1.50))
mergeluma(blur(0.2))
# Convolution3d or DCTFilter for extreme worse cases.
GripBorders()
LegalClip()
Anyone got a clue as to help me?Fun in the sun, Oh no my friend, Fun on the sun!
VirtualDub: Working with MKV & MP4 (frame jumps, RGB decompression etc.)
By pokepika in forum Video ConversionReplies: 4Last Post: 21st Sep 2011, 19:28 -
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 23:17 -
VirtualDub Compression Not Working
By jjis in forum EditingReplies: 3Last Post: 3rd Apr 2011, 09:14 -
VirtualDub-1.6.19 not working
By no1knoe in forum Newbie / General discussionsReplies: 2Last Post: 30th Aug 2007, 12:50 -
Editing AVI, VirtualDub Error, Codecs not working.Can i delete afew scenes?
By UmmAddan in forum EditingReplies: 5Last Post: 23rd May 2007, 05:29
