  1. I just encoded an 82 min. movie and I want to put it on 1 80 min. cd. My only problem is that my file is 810 mb which is too big for nero. Someone told me I could re-encode it with lower audio settings to get my file size smaller without noticably lowering the quality of my movie. My question is how do I lower my audio settings using TMPG? or Does anyone know of another solution to my problem? Thx, in advance.
    Feb 2001
    Berlin, Germany
    If you lower the bitrate, your VCD becomes a XVCD.
    Before you start I suggest to install tooLAME and use it as external audio encoder. Option> enviromental setting> external tool> Layer-2.
    File> MPEG tools> simple demultiplex
    Select the new .mp2 file as audio source, select file> output to file> wave file, save .wav.
    Select new .wav file as audio source and the .m2v file as video source. Make sure, the correct framerate is selected.
    Then check "audio only" , go to setting> audio tab.
    Select Layer-2 44100kHz and 128kbps.
    File> MPEG tools>simple multiplex.
    The 2nd solution is to cut one or two minutes.
    http://www.vcdhelp.com/editmpg.htm
  3. Why dont`t you use 90-Min.-CDs ?
