I just bought 100 Riteks from Shop4Tech and 5 in a row have failed to write with a "Media Sense Error". This is good and bad news, as I have found the "Media Sense Error" is the hardware surrendering prior to writing, so they're not coasters.
Is there any way to find out the Disk Media Info on the Mac? I tried Virtual PC and some PC utilities, but they either don't recognize the drive (a Pioneer 105) or give generic info (N/A not a pressed disk). I really suspect these are G03s instead of G04s but I really don't want to burn one to prove them wrong...
-Glenn
I am not aware of a way to check media codes on a mac, unfortunately.
the only way i know is to use a pc if you have one, or a friends if they have one.
anyone else care to agree/disagree? -
have you tried using a differnt burning program? Sometimes Toast can be a bit picky... i have that error before and solved it using Dragon Burn instead.
About the most disc info you are going to be able to get on the Mac is in toast by "getting disc info", which pretty much sucks. -
Originally Posted by ZeroSix
wow, how sweet that would be.
I wonder if apple takes update recommendation advice
Media Info Not seeing all subtitles
By cal_tony in forum SubtitleReplies: 0Last Post: 15th Apr 2012, 22:43 -
Verbatim LTH Media...Info
By New Bee in forum MediaReplies: 2Last Post: 13th Feb 2011, 05:58 -
Media Info query
By Bully9 in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2011, 08:54 -
Media Info and AVISynth
By ZedVamp in forum Video ConversionReplies: 0Last Post: 7th Feb 2009, 14:25 -
question about where bad hard drive disk sector info is stored
By jimdagys in forum ComputerReplies: 1Last Post: 20th Apr 2008, 16:24
