Any suggestons for converting MPG (actually M2V) files to DV with minimal loss in quality?
My problem. I'm using Memories on TV which only produces an M2V "slideshow"--no option for encoding directly to DV. I want to convert to DV so that I can input these into Premiere 6.5 for additional editing with video clips.
Incidentally, the M2v file from MOT is encoded in progressive mode. My current procedure is to use Vdub-Mpeg and encode to DV using the MainConcept DV codec (2.11). I have played around with various de-interlacing and sharpening filters and found a combination that leads to "OK" ouput, although still less sharp than the original.
Any suggestions? Thanks in advance.
wwaag
well you can upgrade to the latest MC Dv codec ... what you are doing is basicly the way to do it ..
though why are you de-interlacing ?
also --you should change premiere (if its 6.5) to use the MC codec instead of the default Microsoft codec .. as that will improve quality a lot when it comes time to re-render.."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
BJ_M
Thanks for the quick reply. Why de-interlace. Since the m2v file is a slideshow (or moving very slowly using Ken Burns effect), you may want to "pause". Using de-interlacing (blend mode in Vdub) actually produces a better looking "still" when paused, although in normal "play" mode, there is a slight blurring (reason for using sharpening filter). Without de-interlacing, the image when "paused" looks terrible--lots of jaggies. The m2v output from MOT is interesting in that the image is actually "sharper" when paused compared during normal play. I suspect this is the reason they encode as non-interlaced.
Any guide or thread regarding changing the DV codec in Premiere? Incidentally, I use the Matrox RT-10 card so I don't know if it uses its own codec or the microsoft codec.
Again, thanks for the reply.
wwaag
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Converting VOB files to Mpg..
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2009, 22:27 -
Converting .mpg-files to .vob-files ?
By stuckinsnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 09:11 -
plan for converting SageTV mpg's to smaller files.
By Verlager in forum LinuxReplies: 7Last Post: 6th Feb 2008, 22:56 -
Need help converting SCM files to mpg or avi or rmvb or wmv
By US Guy in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 01:01
