I have an mpg capture of a movie 1 hr 53 min long captured to(DVD-NTSC size = 3.53 gigs. I have tried to use the tmpeng encoder, but it ruins the quality of the capture. The video looks like as if I was watching a movie through a rain streaked window. However, if I take the mpg and import it into Sonic MyDVD it states that the capture is to big. Okay, so I performed a test I captured 1 hour of the same video - imported into MyDVD - the software transcoded the mpg and burned a DVD. It runs fine in my stand aolone DVD player attached to my TV. Cool! However, Sonic MyDVD can't transcode and burn a large amount of data because of the way it handles the audio. I've tried some encoding software biut I don't like the video quality it produces. Transcoding seems to give me better results.
What I would like to do is this: A). Somehow with software compress/reduce the size of the mpg files size B). Transcode the mpg then compress/shrink the file size.
My thought is this: I don't care if it is an all-in-one solution. I would like to take an Mpg and rather than encode it, I want to, in whatever appropraite order, transcode, compress/shrink, image to HD if appropriate and burn. I'm really stcuk on this transcode thing because the end product seems to be so much better
Thanks in advance
MyDVD converts all the audio to LPCM. This is uncompressed and so takes up loads of space. This is why you cant make longer playing DVD's with MyDVD.
What you need to do is use a different authoring program that will accept the Mp2 audio in your original mpeg (assuming it is otherwise DVD compliant). I suggest you take a look at TmpGenc DVD Author or DVD-Lab. Both are great VFM. -
If my memory serves me correctly Sonic MyDVD will transcode video/audio to it's "Best" settings if the file isn't DVD Compliant (framesize, bitrate, etc). These setting can be found in the Help File for the program. I think "Best" means 8.0Mbps. If so, then your 2h movie would become to big.
If authorizing software try to 'transcode video' on me I generally end the process and inspect whats wrong with my file, then redo the project using the proper compliant settings.
Good luck.
Shrinking Down a Video
By niteghost in forum Newbie / General discussionsReplies: 8Last Post: 12th Aug 2009, 07:58 -
Shrinking Video
By Leo48 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2009, 13:46 -
Which is better - shrinking with DVDShrink or......
By robertazimmerman in forum DVD RippingReplies: 21Last Post: 4th Feb 2008, 14:12 -
Preventing DVDFab HD Decrypter transcoding (shrinking) your files
By mazinz in forum DVD RippingReplies: 4Last Post: 30th Jan 2008, 19:08 -
Shrinking 5.2 GB of video
By moviebuff2 in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2008, 12:43
