I'm confused. What has compression got to do with the way that CBR and VBR encoding allocates data? Smaller files sizes are not due to compression but a smaller average bit-rate - if a CBR and VBR encode have the same average bit-rate then the file sizes will be near equal.Originally Posted by SHS
Results 31 to 42 of 42
Regards,
Rob -
yes, you are right, it is SHS that is incorrect when he says that.Originally Posted by rhegedus
Complete rubbish.Originally Posted by SHS -
Hi all,
as a remark, I'd like to state that capping (or enconding) with 9600K bitrate for DVD, really makes things better. If you plan to put up to 1 hour only in a DVD, and you source is clean and good enough, it really worth. Why? Test it. You will improve quality a lot. A simple test is, after burning a DVD with, say, 6000K and another with 9600k (of course the same footage!), play them on a standalone DVD connected to a TV set. FF or RW both and check the quality as the DVD moves backward or forward. Also, there is an improve on sharpness as well. -
Don't confuse single pass VBR with CQ. It's not true VBR, since it's not allocating bitrate throughout the entire video. It is simply limiting any given frame/GOP to you 'max' setting. And yes, it's impossible to predict the file size, except to say it will be less than some high bitrate CBR.
Try capturing VBR with a max of 9500 and a min of 300 and see what you get..... I mean it's VBR, why set your max to 6000?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Google Translation (LOL, J/K):Originally Posted by SHS
Lordsmurf, it is very difficult to understand the difference between VBR and CBR.
CBR mode does all full frames all the time just like AVI, DV, etc but it doesn't give you very efficient compression.
VBR mode only does part of the frame (the part that changes between frames) which is more efficient compression as sometimes your filesize is 15% smaller, even more.
Was that a good translation do you think?
Compression isn't really applicable to video in the same way it is with ZIP/RAR. Video 'compression' is just trying to recreate a frame in as much detail as possible with the amount of bits a program is allowed to allocate. VBR just determines which scenes can make best use of having more bits.
Anyway. The difference betwenn VBR and CBR is...
CBR has the same amount of bits allocated to each GOP. VBR has different amounts of bits allocated to each GOP.
Using infomation from previous GOPs is completely irrelevant. That is termed 'Closed/Open GOP' respectively. VBR works by analysing how much detail/movement there is in a frame, and allocates more bits to GOPs (which, in turn gives more bits to each frame) where there is a lot of detail.
Am I right in saying this?
I'm pretty sure I got at least most of that right. -
CBR really means that the bit rate is constant into the buffer .. the acual measured bitrate may go up and down a bit .... not as much as CQ or VBR though ....
One thing I've noticed is that when using editing software, the seek time to a new edit location is much faster with CBR files than with VBR files.
fREBieware- you get what you pay for. -
bugster
It could recall that ULR page that show the diff of CBR vs VBR I would post it but I can't seem to find it rigth now.
The page I'm ref to had picture show this so I guest he could done it wrong I though it was on 100fps.com but that not it so someday I run across it againe and sent you the URL to it. -
See BJ_M's post above for a brief but accurate description of the diff between VBR and CBR. This is assuming we are talking about mpeg compression of course. You are right that DV is CBR and that it compresses each frame to be the same size as the previous and there is no reference to previous or future frames, but this isn't how CBR mpeg's work.Originally Posted by SHS
As for Avi which you mentioned also, this is just a wrapper format and can contain video encoded in many different forms, including mpeg 1 or 2, though this is rare. -
bothOriginally Posted by jgandara"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I agree with BJ_M.
But most are CBR, since most source the industry use are perfect, noiseless.
cbr to vbr
By dynamix1 in forum AudioReplies: 1Last Post: 17th Mar 2009, 15:12 -
CBR vs VBR
By prl in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 19:48 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
VBR or CBR?
By dizzie in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2007, 15:28 -
CBR VBR Discussion
By josel in forum Newbie / General discussionsReplies: 11Last Post: 19th May 2007, 20:51
