I'm trying to convert my divx and avi files to dvd-rs, but I want to keep good sound quality. I'm willing to spend the extra time to convert it to dts or 5.1 if that is possible. How can I get good sound? Is there a guide of some sort somewhere?
You can't improve on the sound quality that is in your AVi's. Converting to Ac3 or DTS will not help.
What format is the sound in your avi's? -
In that case either convert to mp2, if your DVD player supports it (most do but some US players do not), LPCM or 2 chan Ac3. The quality will be pretty much the same as the Mp3.
You could convert the mp3 to wav n then the wav to ac3 using Softencode or something like it.
You could then end up with a 'surround sound' 5.1 mix. The actual quality wont be improved but youll have a surround sound effect. -
You could try opening the file in cooledit/adobe audition or soundforge, or similar audio editing program and try applying some filters to enhance the sound, but you may not get the exact results you want. If you own a audio editing program, give it a try.
"The software said Win XP or better, so I Installed Linux"
What is a good sound card for HTPC?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 31Last Post: 20th Jan 2011, 08:59 -
camcorder with good sound options.. ? Or..?
By OMNICELL in forum AudioReplies: 1Last Post: 18th Jan 2010, 21:22 -
what's a good sound card to use for my captures?
By kukuo522 in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2008, 20:53 -
Why New Music Doesn't Sound As Good As It Did
By MeDiCo_BrUjO in forum Off topicReplies: 5Last Post: 12th Jul 2007, 17:44 -
How do I record a my voice at a good sound level?
By OM2 in forum Newbie / General discussionsReplies: 6Last Post: 15th May 2007, 13:31
