thanks
have you tried downloading the updates for powerdvd?
i know for version 4 (XP) there is an update that specifically addresses remote control issues..
if you're using version 5, then i doubt you should be having any problems.. i recently redownloaded the patch for v4 and noticed that they did have patches for version 5..
personally, i dont like version 5.. very poor performance when it comes to svcd & vcd. -
Thanks for your input jeex. I wish it were that simple.
I use this product for videocard/capture setup.
http://<a class="contentlink" href="http://www.comprousa.com/products/vmcinema.htm" ta...cinema.htm</a>
Part of the package is a remote control to operate ComproDVD (re-skinned PowerDVD)
I've removed ComproDVD and now use PowerDVD instead (more features) but would like to get the remote working for PowerDVD.
The remote also operates ComproPVR, my capture program.
If I try and install PowerDVD while ComproDVD is still installed, the install stops and says that PowerDVD is already installed.
Here is a piccy of the remote,
Remote control of computer?
By cwb in forum Media Center PC / MediaCentersReplies: 9Last Post: 29th May 2010, 18:29 -
Universal Remote Control
By titilucky in forum DVD & Blu-ray RecordersReplies: 11Last Post: 3rd Nov 2008, 14:31 -
Remote control for VBox?
By slytrans69 in forum Media Center PC / MediaCentersReplies: 0Last Post: 15th Aug 2008, 15:53 -
remote desktop control
By pcb in forum ComputerReplies: 11Last Post: 9th May 2008, 06:00 -
Remote PC Admin Control?
By Xenogear900 in forum ComputerReplies: 6Last Post: 11th Oct 2007, 08:35
