Hi everybody
Has anybody come across the problem i am having with my LG GSA 4040B FIRMWARE A301
I have Burnt 12 films from my collection of DVD,S. all @ 4x speed
6 have worked perfectly All under 4,283,918 in size
6 have not All over 4,392.254 in size Play ok until near end of films
11 burnt too Bulkpaq orange 4x.speed gen 4 (4 bad ) freeze and picture break up
1 too Bigpockets 4xspeed (bad ) freeze and picture break up
Software used is a mix of Decrypter, DVDshrink .CloneDVD
So to am questions
1 Is my writer faulty
2 Are the blank media c##p (as i have read good reports about Bp orange )
As a Newbie i look forward to any comments or suggestions
THANKS
It is most probably your media, but, to track it down, use all the resources available to you on this site.
Look up your media (left DVD MEDIA) and read all the comments from members/users there.
Do the same for your burner (in DVD WRITERS) and check what works best for other owners.
Repeat that process for your Player(s) (DVD PLAYERS) and read what discs work best.
For problem media, especially toward the end, you can try reducing burn speed and limiting size to less than 4G.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
Problems with DVD LG GSA-4160B
By Jomapil in forum DVD & Blu-ray WritersReplies: 6Last Post: 11th Feb 2009, 00:33 -
LG GSA H55N region free?
By Ace-Of-Spades in forum DVD & Blu-ray WritersReplies: 2Last Post: 6th Feb 2009, 09:18 -
lg gsa-4120b dvdwriter
By mustang1967 in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jun 2008, 00:50 -
Drive problem- LG GSA-H10L
By pinetop in forum ComputerReplies: 9Last Post: 17th Apr 2008, 02:39 -
Video capture with LG GSA-5169D
By henrik.uggla in forum LinuxReplies: 2Last Post: 25th Jun 2007, 16:59
