I'm new to the DVD burner scene. I have a Pioneer DVD writer. I can sucessfully copy my DVD movies onto a DVD-RW disk. When I try to use a DVD +R I get rather expensive coaster. What can I do to record on the "R" disks?
I've had some problems burning DVD +Rs (with Sony DVD writer). I've found that Nero had less trouble than other DVD burn programs. I've also found that if I burn to a DVD-R, DVD-RW or DVD+R then I can use the disk-copy of Easy CD-DVD Creator to copy that to a +R disk.
what specifically is it doing?
I was having a few issues till I updated to the latest version of xcopy
also found that using some herrie hacked firmware has ended my days of creating coasters. -
On a +R DVD disk, DVD X Copy Express says the burn was sucessful, but the reader cannot read the disk. I just bought some -R disks and they work fine.
Media Express 3.0.3 Question?
By Darkensteele in forum Capturing and VCRReplies: 0Last Post: 27th Dec 2011, 04:47 -
Blackmagic Media Express question
By trialanderror in forum Capturing and VCRReplies: 0Last Post: 5th Mar 2010, 00:21 -
Final cut express simple question
By thecrock in forum MacReplies: 1Last Post: 17th Apr 2009, 10:48 -
final cut express HD... quick question
By ednarophati in forum MacReplies: 1Last Post: 10th Jul 2007, 10:32 -
old copy of dvd xcopy xpress
By wisconsin girl in forum DVD RippingReplies: 2Last Post: 3rd Jun 2007, 17:19
