hi
any1 had any problems with band of brothers
my backup copies were fine a few months ago
now the pictures are breaking up and the disc is skipping
any ideas why this has started happening
the whole boxset like that
the discs are in great condition
nuff respect
Sounds like a media issue. Have you backup up anything else on this discs and if so, are they as old or older than the BoB backups? That might be the only way to tell, unless you have other DVD players to test the discs on.
there datawrite 4 speed dvdr
ive had no problems with them apart from bob
i burned them 2 months agonuff respect -
Thats enough to make a man cry; I love my Band of Brothers Collection.
No problems. Did you try them in another player? -
Greetings,
What is the brand name of your DVD media?
I am doing a lot of researches since 2-3 weeks and I figured out (Thanks to many people here and especially thanks to lord smurf) that some cheap media don't last and you lose the data on the dvd.
Many readings tend to say to go with RITEK and OPTODISC for cheap media. For a comprehensive guide, go to lordsmurf site and read his guide on dvds. It is one of the best I read.
Thank you -
ive backed up over 100 of my movies on the datawrite aka princo dvds
its just bob that gave my problemsnuff respect -
If you go back and check a lot of your dvds youll have problems. I burnt over 100 princos and am just now having problems (including BOB). Now that im on Riteks there is no problem at all.
I started with Retek and have done close to 250 burns. I only have had 4 problem burns, one was a bad disk, 2 I used the computer during the burn, and the last looks like the computer restarted in the middle of a burn.
I know there are cheaper options but I see no reason to experiment. I buy 100 at a time and like knowing that it will work.
Dual band or not?
By yamatosoul in forum Video Streaming DownloadingReplies: 3Last Post: 30th Nov 2009, 17:35 -
Green Band Problem
By fusion99 in forum Blu-ray RippingReplies: 4Last Post: 6th Aug 2009, 11:58 -
What tool can back up the “Blood Brothers”?
By coody in forum DVD RippingReplies: 2Last Post: 9th Jul 2008, 11:46 -
Smash Brothers Brawl
By seven_deuce offsuit in forum Off topicReplies: 0Last Post: 14th Mar 2008, 21:14 -
Band Music Video
By sekthree in forum EditingReplies: 4Last Post: 22nd Sep 2007, 03:21
