Having installed dvd2svcd, I ran it, it ripped the vob files then launched tmpgenc. It started encoding a test file, a short file about 4 mins long, when it had finished it kept repeating to encode the same file, it would not continue with the main vob files.
Anybody any ideas
Here is my log file
cheers in advance
WNASPI32.DLL 1.0.0.1
- 20/10/2003 17:54:59
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.2.1 build 3
Initializing
- D:\VIDEO_TS\VTS_02_0.IFO
- D:\VIDEO_TS\VTS_02_1.vob
- D:\VIDEO_TS\VTS_02_2.vob
- D:\VIDEO_TS\VTS_02_3.vob
- D:\VIDEO_TS\VTS_02_4.vob
- D:\VIDEO_TS\VTS_02_5.vob
- D:\VIDEO_TS\VTS_02_6.vob
Initializing finished.
- 20/10/2003 17:55:04
- Free on drive C: 11836.25 mb
- Internal rip
Preparing vobfiles to be ripped:
Ripping: D:\VIDEO_TS\VTS_02_1.vob
Ripping: D:\VIDEO_TS\VTS_02_2.vob
Ripping: D:\VIDEO_TS\VTS_02_3.vob
Framerate: 25000
Ripping finished. Speed: 1282
- 20/10/2003 18:22:58
- DVD2AVI
Creating DVD2AVI INI file:
- C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\Program Files\DVD2SVCD\Movie\DVD2AVI_Project_file] -IF=[C:\Program Files\DVD2SVCD\Movie\VTS_02_1.vob,C:\Program Files\DVD2SVCD\Movie\VTS_02_2.vob,C:\Program Files\DVD2SVCD\Movie\VTS_02_3.vob]
Framerate: 25000
DVD2AVI processing done.
- 20/10/2003 18:31:39
- Free on drive C: 9745.50 mb
- AUDIO Extraction
Found AC3 stream id: 0x80
Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3
Audio1 delay: 0 ms
Framerate: 25000
Audio extraction finished.
- 20/10/2003 18:42:08
- Free on drive C: 9609.50 mb
- AUDIO conversion
Encoding Audio. Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3" -output "C:\PROGRA~1\DVD2SVCD\MOVIE\Encoded_audio_1.mp 2" -logfile "C:\PROGRA~1\DVD2SVCD\MOVIE\Encoded_audio_1.lo g" ) -azid( -L -3db -C 0db -S 0db -c normal -s surround -g max ) -shibatch( --rate 44100 ) -2lame( -e -b 192 -m s )
Audio conversion of C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 20/10/2003 19:14:00
- Free on drive C: 9542.14 mb
- Video Encoding using TMPGEnc
- Encoding Test Clip C:\Program Files\DVD2SVCD\Movie\AviSynth_Script_file_CQ_TEST. avs
Executing TMPGEnc. Commandline:
"C:\MY DOCUMENTS\PROGRAMS\DVD+VCD\TMPGNE\TMPGE\TMPGEnc.ex e" "C:\Program Files\DVD2SVCD\Movie\TMPGEnc_Project_file.tpr" /Encode /Close
Video Encoding finished.
Wanted: 689173478 (673021kb) Predicted: 627721107 (613009kb) Using CQ Value: 25.00
Calculated next CQ Value: 27.23
Wanted: 689173478 (673021kb) Predicted: 23219231 (22675kb) Using CQ Value: 27.23
Calculated next CQ Value: 53.54
Wanted: 689173478 (673021kb) Predicted: 5847535 (5710kb) Using CQ Value: 53.54
Calculated next CQ Value: 106.63
Wanted: 687833614 (671713kb) Predicted: 17228389 (16825kb) Using CQ Value: 106.63
Calculated next CQ Value: 210.58
Wanted: 687833614 (671713kb) Predicted: 489939 (478kb) Using CQ Value: 210.58
Calculated next CQ Value: 421.02
Wanted: 687833614 (671713kb) Predicted: 225252 (220kb) Using CQ Value: 421.02
Calculated next CQ Value: 841.90
Executing [removeme]TMPGEnc[removeme]. Commandline:
"C:\MY DOCUMENTS\PROGRAMS\DVD+VCD\TMPGNE\TMPGE\[removeme]TMPGEnc[removeme].exe" "C:\Program Files\[removeme]DVD2SVCD[removeme]\Movie\TMPGEnc_Project_file.tpr" /Encode /Close
- Encoding Test Clip C:\Program Files\[removeme]DVD2SVCD[removeme]\Movie\AviSynth_Script_file_CQ_TEST.avs
Wanted: 687833614 (671713kb) Predicted: 199225 (195kb) Using CQ Value: 841.90
Calculated next CQ Value: 1683.56
Wanted: 687833614 (671713kb) Predicted: 3861674 (3771kb) Using CQ Value: 1683.56
Calculated next CQ Value: 3357.67
Wanted: 687833614 (671713kb) Predicted: 242288 (237kb) Using CQ Value: 3357.67
Calculated next CQ Value: 6714.15
im having the same problem if you find a solution plz inform me as i will do the same thnkz..
well, dunno of you are still having the problem.........
I had the same, just waited and after a couple of test files it started the conversion. Just hang in there -
It's normal for CQ mode. It has to determine what to set the CQ at, so it does test encodes until it hits a specified point (disk size). CBR or VBR mode won't do this.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
yep just leave it alone and let it do its work. I did the same thing last night and after about 7 test clips it started the final encoding.
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 08:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
I need to test mp4 video file iphone, psp, ipod, blackberry
By timo2009 in forum Video ConversionReplies: 7Last Post: 29th Sep 2009, 16:24 -
Image File Test post after failure to attach
By Snaque in forum TestReplies: 0Last Post: 15th Feb 2009, 15:29 -
how to rip 1.4 gb file to 700mb
By stranzer in forum Video ConversionReplies: 15Last Post: 17th Jun 2008, 16:17
