does anybody know why i can't capture with 48Khz with ATI? i dont know what is wrong with it... it doesn't even give me the option
Results 1 to 9 of 9
Maybe your audio sound card isn't capable of capturing at that sample rate.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
hmm i mya invest in one then..... they are only cheap though aren't they... like £5-£10?
It is possible that your version of MMC does not have that option but since you have not specified your version number I can only speculate.
It is possible as mentioned that your sound card is not capable of capturing at that rate but since you have not specified your sound card I can only speculate.
It is possible that some settings change to your system has caused this problem but since you have not specified if it ever worked I can only speculate.
Seeing a pattern here? -
hmm thanks for the help... i'm sure it will sort itself out sooner or later...
ATI MMC 7.7 and newer has 48hz. You likely have an old one. Update.
the site is being wierd.... is there anywhere else i can download it from?
i think i may need an update
24bit/48kHz for DVD
By iker222 in forum Authoring (DVD)Replies: 11Last Post: 3rd Aug 2009, 07:59 -
Convert at Low Bitrates at 48Khz in Stereo
By ashwin.terminator in forum Newbie / General discussionsReplies: 23Last Post: 23rd Jul 2009, 17:13 -
32khz mpeg to 48khz how to ?
By Videodream in forum Capturing and VCRReplies: 12Last Post: 4th Aug 2008, 09:11 -
DVD-NTSC PVR/TVR capture isn't 48kHz as set to
By wguru in forum Video ConversionReplies: 0Last Post: 28th Jul 2007, 02:38 -
Why was 48khz needed for DVD specs?
By yoda313 in forum AudioReplies: 3Last Post: 7th Jul 2007, 15:57
