  1. I have downloaded all the DD, DTS, THX intromovies as .vob files, is it possible to author a VCD with the DD, DTS intromovies and still have DD, DTS sound?? If yes what app, if no which app should I use when author the movies on a DVD (if thats possible).
    /Kuseman
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    /Kuseman
    Only do that with DVD
    I haven't tried this with TMPGEnc DVD Author yet but it does have a section I think for importing VOB files.
    You can try it for free for up to 30 days or something like that. After that you need to register (buy) it to continue using it as it will lock itself down.
    - John "FulciLives" Coleman
  3. DVD-Lab will let you use VOBs without demuxing them
