Do you Multiplex your sound with your video before authoring or let the authoring program do it? If it is done by say TMPG dvd author will it be in sync or have any problems like that?
Generaly speaking it is better not to multiplex yourself. The only time I did do this myself is when I used Ulead DVD Movie Factory 2 since that program would only accept AC-3 audio if it was muxed in with the VIDEO and imported as a single MPEG file.Originally Posted by Zlash
But I've moved on (thankfully) from using that authoring program so I no longer do that.
From my understanding the authoring program will have to demux a multiplexed MPEG file anyway for the creation of the DVD so no reason to do it yourself.
Plus you sometimes could CAUSE sync problems if you do it yourself anyways.
So it is best to use an Authoring program (like TMPGEnc DVD Author) that accepts seperate VIDEO and AUDIO files and just do it that way.
The authoring program knows what it is doing.
Well most of them
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
Remove Sound From Original DVD And Add My Own Sound To New DVD.
By MrJacobAngle in forum Authoring (DVD)Replies: 7Last Post: 30th Jun 2010, 14:38 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
