I've got a Cyber Home dvd player compatible.
I record my dvd+r with Ulead Workshop with menu and music and blah blah
Of course the menu is perfect but when I try to play the content (movies, episodes, whatever) it appears for 1 sec full screen and then all compact in half a screen
HEEEEEEEELP!!!![]()
Please provide some more information:
1. How did you acquire your MPEGs?
2. What are the precise video/audio properties of the MPEGs as compared to the following properties of MPEGs I routinely edit:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 704 x 480, 29.97 fps
Field Order B
(DVD-NTSC), 4 : 3
Video data rate: Variable (Max. 8800 kbps)
Audio data rate: 256 kbps
MPEG audio layer 2, 48 KHz, Stereo
Did you adjust your project settings to conform to the properties of your DVD compliant source media?
Jerry Jones
http://www.jonesgroup.net -
I get my mpegs via Kazaa or Suprnova
I dont edit before loading them in Ulead Workshop...
Didnt know I had to.
Anyway the properties of one of the files given by Workshop are
File Format MPEG-1(PAL VCD)
VIDEO
Attributes 24 Bits, 352 x 288
Frame Rate 25.000 Frame/Sec
Data Rate 1150 kbps
AUDIO
Layer 2
Bit rate 224 kbps
Attributes 44100H Hz, 16 bit, Stereo
Is ok? And if I should change the properties, how can I?
Thanks a lot!
Split screen, keep aspect ratio and use half of 2 different videos ?
By boulder in forum EditingReplies: 10Last Post: 10th Nov 2009, 11:30 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
MS Word XP PgDn advances the text half-screen only
By walter4h in forum ComputerReplies: 2Last Post: 10th Oct 2007, 21:07 -
MPC DVD playback - I can only see half of the screen
By giaitchison in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2007, 02:02 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 11:16
