Hi,
I am trying to convert a avi file to dvd by using TMPGenc and TMPGenc Author.
Now then, I have read a few of the howto's on this site, and I am a little confused as to which way is best.
For starters' I have extracted the audio from the avi file, by using VDub, and saving as a wav file. Then I opened up TMPGenc and by help of a howto, I changed the settings to what was reccommended. I used the info from this site to setup TMPGenc:
http://dvd-hq.info/Compression.html
That done, I proceeded to start the encoding, by selecting the avi file as video only, and then the wav file as audio, but then the ouput file is now named as a .dvd[m2v + wav].
When that is completed, I am going to use TMPGenc Author to author the dvd.
Buit when I did this before with TMPGenc Author, the dvd [m2v+wav] was loaded, and the built in writing program? burnt the dvd file(s) to the disk.
But I noticed that there was no audio files in the Audio_Ts folder, but then neither are there any in a commercially produced dvd that I have in my DVD drive.
Advise and or corrections appreciated.
Bob Heselwood
What the heck are you asking here?Originally Posted by welz400
Does your final DVD have audio or not?
If it has audio does it sound OK or is there a problem with it?
The AUDIO_TS folder is always empty. It just needs to be there.
Basically, as I know absolutely nothing about dvd convesion and burning them, I just wanted clarification on what I was doing is correct.
It seems that it is from you reply, so thanksBob Heselwood -
Well if you really want to get into the nitty gritty stuff then you have to state exactly what settings you used in TMPGEnc. It doesn't help to point to that guide since it offers a bunch of different options based on your source and we don't even have enough info about the source to know if you did everything correctly assuming you properly followed the TMPGEnc guide.Originally Posted by welz400
The more info the better.
It "looks" like you are doing everything right. If you have a DVD burner burn it to an RW disc and check and see if it works !!
Keep reading the forum and you'll learn little things to help with the quality, etc.
Tom
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Am totally confused with dvd film conversion.
By frenchman96 in forum Video ConversionReplies: 6Last Post: 10th Nov 2010, 09:38 -
confused with avi settings:
By modern saviour in forum Video ConversionReplies: 3Last Post: 4th Oct 2010, 14:52 -
Confused over colorspace (YV12) and DV AVI
By sasuweh in forum Video ConversionReplies: 4Last Post: 30th Sep 2010, 05:34 -
Confused !!! I am trying to convert avi to dvd.
By reneewhite70 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Apr 2009, 14:55
