i just bought a digital camera ,the pictures are in jpeg format ,my question is can i put them on vcd to watch them on my dvdplayer,thx
Here are the guides about making slideshow VCD's:
https://www.videohelp.com/author#9
JPEG is a very common format, and I'm sure you can use it in most of the software in those guides.
If you come across any software that won't take them as JPEGs, use something else - or download a batch-processing image app (see a site like WebAttack for loads of free apps like this), and convert them into the format you need.
cheers,
mcdruid. -
Originally Posted by gringos
Also FYI
What dvd player do you have the apex 1500 will allow you to put picutes on a cd and watch it automatically if I am not mistaken
JPEG to YUV
By mma238 in forum Video ConversionReplies: 20Last Post: 3rd Apr 2011, 11:53 -
M-JPEG codec
By cheerful in forum Software PlayingReplies: 1Last Post: 3rd Mar 2010, 18:43 -
converting .jpeg into video format for slideshow
By rosmari in forum Video ConversionReplies: 40Last Post: 1st Aug 2009, 09:23 -
Why TWO M-JPEG codec entries?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2009, 16:38 -
jpeg to PDF is OK! But PDF to jpeg?
By bryankendall in forum ComputerReplies: 2Last Post: 14th Sep 2008, 15:53
