    Apr 2003
    Largo, FL
    Anyone use WinProducer 3 to author DVDs? When it creates a DVD it makes one large vob file- which Nero can't burn because the vob is larger that 2 GB. Is there any way to change the settings so it will burn smaller vobs?
  2. Originally Posted by BobK
    Never used it, or even heard of it, but for DVD-Video the vob files must be no larger than 1Gb each.
  3. Sorry Folks, I have just seen your messages. I am using WinProducer 3. It is good for capturing, scanning for scene changes, cutting, pasting, etc. But do not try to produce a whole movie with it. It simply does not work. With this product if something works - it really works - there is no problem you can rely on it. But if something does not work you can not do anything about it. There are no parameters to adjust and Intervideo's technical support is next to nothing. So in this case all you have to do is just give up and use some other software to do what you want to do. This does not help much, but good luck.
