  1. The way I learned to encode files 2 mpegwas to run em thru vdub,with these settings,
    vid- direct stream copy
    audio- full process mode
    then run em thru tmpge ,
    well ive got like these 2 or 3 files
    an when I try this it says
    ''No audio Decompressor could be found to decompress the source audio format''
    then again i know sometimes vdub isnt required in order to mpegg a file,
    so i tried to run it straight thru tmpge
    and it wouldnt open the audio part,
    So my question is ,
    Are there any other settings I could use in Vdub[or]Tmpge so this file can be trans 2 mpegg,? Or any other suggestions? or other software?
    ive tried canopus before ,,not for this
    but I just didnt care much for it,
    Someone suggested Vdubplus ac3 or something like that,
    but i couldnt figure it out, cause the settings were differnt
    so i deleted it,
    so if I do need the Vdub + or whatever its called ,,what settings should I use,
    or maybe some directions,,
    thanks alot!
    Bare with me please,,brain cellz not functioning at normal capacity!!
  2. You are missing a codec, quite possible Ac3. Search the forum or look to the guides for details on how to best handle avi's with Ac3 audio, it is covered many times.
    Dec 2002
    What does Gspot say for the audio? My ESP tells me it's AC3/5.1 , which VDUB will do only with the special version ( I personally have 5 versions co-resident, helps a lot despite eveything being different)
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  4. ok which version of Vdub will i need?
    an what settings should I use?
    See when i got instructed on how 2 do all this encodeing stuff
    i was told to use the vdub settings that i mentioned above,\
    [vid-direct strem copy,,aud- full process mode]
    an Ive never really tried to use Vdub any other way or for anything else.
    So Vdub is still kinda greek 2 me,
    so please kinda let me know how 2 set it up,
    ya know like any settings i need an such,,
    thanks,
    BTW, what kinda other stuff can be done w/ vdub?
