hello guys. i have dvds that were ripped with dvd decypher on my hardrive ages ago. i have now purchased a dvd burner. my question is , what is the best way to convert these back to dvd using a dvd-r disks so that i can watch on a standalone dvd player. thanks![]()
Results 1 to 18 of 18
Loads of answers I would check the guides on the left. You could use dvd shrink or dvdone.
1. DVD2AVI to create a DVD2AVI project and extract the AC3.
2. AVISYNTH to set up frame serving.
3. Main Concept, CCE, TMPGEnc (or others) to re-compress the video track. Look into https://www.videohelp.com/calc for help with bitrates.
4. Repeat for other movies...
5. DVD-LAB, Ulead (or others) to author DVD and create DVD files.
6. Nero (or others) to burn disk.
You'll find much help through the guides and forums here (IMO dvdrhelp is about the best place to start) - other sources for help are places like Doom9 (try some google searches). The tools section will give links for all the programs I've mentioned.
I'd recommend you start with RW's - you're going to have a few coasters... -
thanks guys for the quick replies. Most of the rips i have are just under 4 GB in size, do i still have to follow the above recommendations or is there a simpler way?
Follow hardcoreruss's recomendations. I've never used them but I understand they're great for backing up single movies.
I use the routine in my previous post. But I'm generally encoding 1/2 D1 and fitting 3 movies per DVDR (use them on road trips, camping and such). (btw - 1/2 D1 is great for squeezing more onto a disk, if you're interested then look it up in the forums - also search for CVD) -
Originally Posted by kvos
The only time that you have to use DVDshrink, DVD2one, IC, CCE or any other transcoder / encoder is when the dvd is larger than 4.36GB. So that it can be shrunk down to fit on one disk. -
There are lots of other ways to do it too but most involve alot more time and understanding of how a DVD works inorder to accoplish those methods. -
hey guys , done as said, just want to clarify a few things. i dragged the contents of the files created by dvd decrypter ( 4 vob files and 1 ifo file) to video ts folder in nero. i followed guides for the settings and burned the dvd. when i go to play the dvd-r in my pc it opens to a video ts and audio folder., is this normal.
I assume these 'hard drive copies' do work? Did you test them before trying to burn a DVD? If they work on hard drive, then they'll work on a DVD, and they'll work on a settop box is the directory structure is correct.
presto , will this dvd work on a standalone dvd player.?
I was thrown off by this from your first post:
what is the best way to convert these back to dvd using a dvd-r disks so that i can watch on my standalone dvd player -
the files work great off the hard drive using powerdvd on my pc.
Is 'VIDEO_TS' folder in the root of the DVD disk, and the movie files in that folder?
Is the disk 'closed'?
I use "Track at Once (TAO) Closed" and "UDF with Joliet File System" without any problems.
Compare the file structure of a working disk with yours. Are they the same? -
i found what i did wrong . When i originally ripped the dvds with dvd decrypter they were done in IFO , not File format. A member in another forum suggested to run the files thru DVD2ONE to create missing ifo's and bup's . I've done this to a few,and then burnt with nero and so far they work well on my PC, i am going to try them on my friends standalone today, ill let know how i go. thanks guys.
Best method for archival
By mdod in forum EditingReplies: 15Last Post: 25th Mar 2012, 08:47 -
Is there a better method?
By quxote in forum Authoring (DVD)Replies: 4Last Post: 24th Nov 2009, 15:32 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
Which VHS to DVD method for Newbie
By Anonymous8743 in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 07:49 -
IVTC - Best Method?
By wrawlind in forum Video ConversionReplies: 7Last Post: 7th Aug 2007, 16:04
