I screwed up and didn't set the GOP right on my DVD encode. Is there a way to fix this without re-encoding?
No... not as far as I know...
10110101100111012011 <- The bug Bill doesn't talk about. -
I'd bet Your answer would be no.Originally Posted by Zlash
Read this: https://www.videohelp.com/glossary#GOP:%20Group%20Of%20Pictures
Also read about I, B, P Frames and Open GOP.
This stuff IS the encoding. Hard to change without re-encoding.
BTW: You didn't say how you screwed up. You can change the field order for example, on interlaced video.
Edit: Better to link than to quoteI mean it in the nicest way. -
The GOP was set to no limit or whatever the default is in TMPG instead of 18, and the output "interval of sequence header" was 0 instead of 1.
You can't change either without a re-encode. This info may be helpful.
The question now is do they matter?
Well there is a spec for DVD and if you are too far off, your player may complain. You can use bitrate viewer and maybe rempeg to see the GOP frame length.Originally Posted by Zlash
I'm not sure what zero would do. For VCD you could not set chapter points if this was the case. For DVD, I don't know.and the output "interval of sequence header" was 0 instead of 1.
PS: I am far from an expert. Read up and see what you think.I mean it in the nicest way. -
Well I got those numbers from the default DVD template in TMPG and thier apparently not set right when you make a custom template.
I was trying to import the file into Tmpg DVD Author and it was complaining about the GOP headers and wouldn't open the file. That was my original problem.
I redid a small clip and Author opened it up fine with GOP set to 18. I guess I'll be re-ecoding, but that's ok I guess since my DVD burner won't be here until tommorow anyway.... -
Good for you !Originally Posted by Zlash
Too many people seem to post here and wait for the best answer. The only real way to know what works for you is to do it. I've been slowly learning the why, but the how and what truely come from test, trial, and error.
Repairing mp4 headers manually.
By Wojo J in forum Newbie / General discussionsReplies: 6Last Post: 31st Dec 2011, 09:01 -
Problem with missing headers
By twentworth in forum DVD RippingReplies: 8Last Post: 22nd Jan 2011, 02:19 -
Fix Av sync without reencoding!! perfect!
By duhmez in forum SVCD2DVD & VOB2MPGReplies: 27Last Post: 15th Apr 2010, 11:26 -
Possible to search headers of Usenet newsgroup?
By sdsumike619 in forum ComputerReplies: 15Last Post: 14th Sep 2009, 23:42 -
Chapters and GOP Headers with Adobe Encore
By g1275 in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2007, 15:30
