I received a note from TMPGEnc that 2 pass only works directly with type II AVI. The problem is that ULead VS 6 would not accept type II files, only type I. I assume it only outputs in type I.
Is there a way to have ULead VS 6 output in type II as I use this for editing?
There are some tools that convert from type 1 to type 2.
like the Canopus DV File Converter. look at the tools section.Just because you aren't paranoid, doesn't mean they aren't out to get you! -
It's been a few years, but if I remember correctly, Ulead Studio 6 only captures in type-1, but can output to type-2. Look in the output settings.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 06:19 -
Virtual Dub 1st & 2nd Pass Encoding
By OrchestraAndChoir in forum Video ConversionReplies: 10Last Post: 22nd Jul 2012, 08:20 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Solved- How to do 2 -pass avi encoding with VirtualDub Mod
By jimdagys in forum Video ConversionReplies: 0Last Post: 23rd Nov 2009, 00:07 -
Procoder & 2 pass encoding
By themaster1 in forum Video ConversionReplies: 0Last Post: 17th Jan 2009, 22:48
