I know u can't get it when making a SVCD.. But when u make a DVD from a avi(divx)? The input file is ofcourse 448kb 5ch audio. On my amplifier i want the DTS symbol to "highlight"...
Results 1 to 16 of 16
Don't confuse DTS and AC5.1 . They aren't the same. And I've never seen a DviX with DTS, but many with 2 or 5.1 channel digital audio. And no, SVCD doens't support it, but it does support 2 channel Dolby Surround audio.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Ok so should i take this as a ..NO u can't get DTS from a (divx 5ch) with the program AVI2DVD when making a DVDR ?
Now you have gone and confused me. The subject of your posts inplies your making a SVCD. Are you trying to make a DVD? That's easier.
Do you mean DTS or do you mean AC5.1? It all depends on what your authoring program supports. TMPG Author supports 5.1. Just drop in the AC5.1 and the M2V file and off you go. Basiccly you strip out the audio and convert the video, pretty simple. Never seen an AVI with a DTS track (to too effing big, actually bigger than most video rates for a DivX).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thought I made it clear that it was dvdr ... sorry. I use the program DVD2SVCD with the AVI2DVD option...
And I want DTS audio..or when I play it on my standalone dvdplayer with my amplifier it should say DTS not dolbysurrond... Like it does when I play my backup dvd's ripped from the original dvd.... -
its not DTS audio tho; AC3 is a dloby digital file
DTS and Dolby are competitors, formats are not interchangeable -
Don't worry Dolby Digital is still surround, just not as many channels as true DTS.
Ulead DVD MF 2.0 with AC3 Powerpack didn't work? Weird.
I don't really know anything about DVD Lab. Try it
Here are some threads and guides related to your project:
https://www.videohelp.com/forum/archive/t173245.html
https://www.videohelp.com/forum/archive/t176434.html [maybe u can try ulead dvd ws] http://www.ulead.com/dws/ac3.htm
http://www.google.com/search?s=main&as_q=ac+3+dvd&domains=www.dvdrhelp.com&sitesearch=...p.com&safe=off -
I have a question about this, after you separte the audio (and converted to ac3) and video, do you put it together? Is that how it works?
If I have the mpeg2, can separete audio and video? is any reencoding done to the file? -
Yeah u prob. woudnt hear the diff...Originally Posted by Draven
jgandara, u put it back together thru multiplexing (muxing). if u have the mpeg2 u can separtae A/V, no re-encoding neccessary unless u want a new MPEG2 -
Yes he is right..
DVD lab can do the multiplexing for u.. Or u can open the mpeg 2 in the new version of virtual dub and exctract the audio to a wav there. Convert the mp2 or wav file to ac3 with besweet.. -
I have one more question..
What is the difference between 2ch stereo and 2ch dolby surrond ??
Is there any use to convert a 2 ch ac3 stereo stream to 2ch dolby surrond when u want to put it in a DVDR? This is when u want to play it in youre hometheater cinema.. -
I really don't know! Sometimes when i save a wav w/ virtualdub and convert with besweet to true stereo wav, it reads it as a "Dolby-Surround Compatible Stereo" file...Originally Posted by Draven
About the conversion, if u do taht it will probably sound more like virtual surroubnd sound, not "true" because its comin from a stereo file
DVD-Audio to Dolby TrueHD or DTS-HD
By greymalkin in forum AudioReplies: 2Last Post: 20th Apr 2011, 12:01 -
MKV to dvd while keeping the dts audio intact
By Loonatik in forum Authoring (DVD)Replies: 13Last Post: 30th Mar 2010, 11:41 -
Is it still DTS audio if its at 448kb/s on a dvd?
By yoda313 in forum AudioReplies: 8Last Post: 7th Sep 2009, 08:06 -
Authoring a DVD with DTS 5.1 Audio
By wanguy2k in forum Authoring (DVD)Replies: 4Last Post: 12th Sep 2007, 18:52 -
How to convert AVI with DTS audio to DVD
By Jean in forum Video ConversionReplies: 6Last Post: 24th Aug 2007, 02:25
