In my never ending quest to find the truth about DVD-R degration I came across a guy on IRC who had just thrown away about 100 of his discs because they no longer were being read by dvd-roms or dvd players.
These were Princo brand. 2X and about a year old.
To quote what he said: "Princo set me up the bomb"
Princo? Just say no!
Results 1 to 9 of 9
:cD Ah! I love it! Great post - for the big smile factor! :cD
Thanks for that!There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Even lordsmurf stopped using them
https://www.videohelp.com/forum/viewtopic.php?p=688745&highlight=#688745You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
No! No! No! No!Originally Posted by DVDEmperor
I rate princos I use bulkpaq orange 4x and I have never had a single coaster.
Ask him if those 100 dvd-r's had labels on them? That usually screws up the dvd-r.
I asked, they did not have labels on them. They were also burned at 2X. Apparently when he puts in the Princos into his dvd player it says: "Not a valid format". When he puts it into his DVD-ROM computer, it reads it for a second or two then ejects it out, as if it were blank.
He has tested nearly 60 of them, all the same, he has now thrown them away.
I told him to get an account on here so he could post his findings so you should see something soon from him directly.
Thanks for posts! -
Well, all your friend would have had to do was read this forum last year. It was clear back then that the DVD-Rs made by Princo were crap.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
What kind of burner and authoring software did he use? I have had a lot of trouble with burning at 2x on those maxell unbranded discs. They would show it right from the start. Don't burn at 2x unless you are using branded media. I have a pioneer 104 and it worked fine with fuji branded, but with maxell unbranded, 30 percent of them useless after 2x, some even bad after 1x. I am now using samsung bealls with complete satisfaction.
DVDDecrypter IFO Mode - How do I know what cells belong to an angle?
By Gatlinator in forum DVD RippingReplies: 6Last Post: 26th Dec 2010, 05:03 -
This Old Princo
By hech54 in forum MediaReplies: 10Last Post: 16th Oct 2009, 18:01
