  1. I have a dvd that do not play on my dvd player cause of the menu.
    I'd like to join the vob file of the movie and make another menu.
    Could anyone help me please?
    THanks
  2. How to combine multiple VOBS to one big VOB.
    There are many ways to do this. The easiest way is with DVD - DECRYPTER.
    Put the DVD in your computer.
    Run DVD Decrypter
    Select IFO mode
    Under the TOOLS menu, select "SETTING"
    A SETTING window will appear.
    Select the "IFO MODE" tab.
    Change "File Splitting" to "NONE"
    Select "OK" to close the setting window.
    Decrypter should have automatically selected all the VOBs for your main movie.
    Start the decrypting process. It will take the VOBs from the DVD, combine them all and put the new VOB on your harddrive.
    (If you like to use FILE MODE, change it's settings to "file splitting = none" also.)
  3. And Then how can I make another menu ?
  4. One more thing
    Now I have four vob files
    what software can I use to join all four in one and how?
    and sorry for so many questions
  5. I pretty much had the same problem to solve and I posted the method here:
    https://www.videohelp.com/forum/viewtopic.php?t=184103
    Hope this helps you out.. It was a pain for me for a while.. lol
  6. U used dvd-lab 1.3 beta 5 ?
    I was using 1.0 and didn't have the option to join
    Thank u
