Using that logic to gauge your purchase when dealing with technology, you would end up not buying anything, because the next best thing is always just around the corner.Originally Posted by bpopman
When I purchased my first DVD burner in 2001, it was $802. The Pioneer A03 only burns at 2x with media but mostly 1x. Had I of waited watied for the next burner, I'd still be waiting today for the A07.
I now own 4 Panasonic LF-D311s (also 1x), and 3 Pioneer A05s. My A03 is still going strong, and gets used everyday at 1x writing speed.
In short, even though 16x and dual layer are around the corner, if you need/want to burn today, go for it. No matter the writing speed, even 4x burning only takes 15minutes for a full disc.
If you compare CD burners, I have both an 8x burner, and a 4x burner, neither are obsolete today.
Results 31 to 40 of 40
I think rather than speed, the next interesting deveolpment will be dual layer burning. I honestly didn't think this would be possible (burning the second layer would erase the first) but apparently it will be with us next year.
hey all;
i see that we are getting into disc spinning and rpm rates of drives causing disc to shatter. If your in the U.S. try to check out re-run of a Discovery show titled Myth Busters. This show takes everyday myths and attempts to prove them fact or fiction. They actually did several different tests to rev up discs to shatter them. they were unable to spin the actual cd rom drive up to what they stated i believe closier 30,000 rpm failure speed. The drives were only spining around 19,000. They ended up using a router motor and another hispeed electric drill motor to shatter discs around 25,000. They microwaved and surface scratched discs, left them in the sun etc. to see how it effected the shatter. Let me tell you the pieces were impedding into a dummie made of a different rubber/gel they called ballistics gel. Check it out some of their forum discussion and website
http://dsc.discovery.com/fansites/mythbusters/about/about.html
http://discovery.infopop.net/1/OpenTopic?q=Y&a=frm&s=6941912904&f=9401967776&p=2 -
They say the most dangerous part of a car is the nut behind the steering wheel.
If you are planning to burn DVD's of the kids, then you may well spend say 8hours caputuring, editing and authoring, then say 20 minutes burning, ie 8H20m. With the faster burner due in the shop "real soon" your DVD may take 8H10m. -
Originally Posted by disturbed1
What I was getting at, according to something I read not too long ago, was that physics dicates either the inner (or outer) actually moves at an apparent rate faster than the other. While CLV means the laser moves at the same speed, and CAV speed up or slows down, that's not the issue. In fact, I was under the understanding that CAV was invented to combat this little piece of science. I'll have to look up that info again.
My drives are fine.Want my help? Ask here! (not via PM!)
Here's what CDfreaks had to predict:
Computex report about the trends in the DVD burner market
Posted by Johnny on 26 September 2003 - 11:04 - Source: PCWelt.de
The German website PCWelt.de has posted a report from the Computex show in Taipei with interesting information about coming DVD writers. Here is a short summary of their article in English:
The DVD+R/RW format is likely to become the dominating format in 2004 according to most drive and media manufacturers.
Lite-On will introduce an 8x DVD writer, the LDW-811S, in late October. A 12x model could follow as early as in the end of Q1 2004.
AOpen will introduce a 12x DVD+R/RW writer in the beginning of 2004.
16x writers could appear in 2004 and will be the max speed for DVD burners.
CMC, Ritek and an unnamed Japanese manufacturer will start mass production of 8x DVD+R media in mid October.
Sony has developed a dual layer DVD+R blank but it will likely never reach production stage because the drives needed to burn it will be too expensive.
http://www.cdfreaks.com/news/8051 -
Just something for other people, some seem to have a problem of starting fast, then slowing down.
Report back on your findings about the CLV and CAV, I'd like to know more about it too. -
the outer edge of a disk moves faster than the inner edge of the disk because the outer edge has to go farther. It has to do with distance and circumference.
Hunting, sure i'll go hunting. When is cow season? -
Originally Posted by tgm4883
At any rate, this is part of limits you to faster speeds and why a 16x CD-R and a 52 CD-R are only a minute or two apart in speed.
Maybe it's that the 4x DVD-R burn STARTS at 4.3x and slow down to about 2x or 1x by the end. My source had his info flipped. This makes more sense actually.
Multiple lasers and new ways to spin are the only way to fix this. But even that brings in new problems with heat and accuracy.Want my help? Ask here! (not via PM!)
Originally Posted by bokkasrealm
I would rather predict that 78rpm records take over!
Add this:
2016 Bill Gates becomes president.......err make that emperor!
PAL -> NTSC DVD Writers?
By tac7 in forum DVD & Blu-ray WritersReplies: 4Last Post: 2nd Aug 2010, 21:34 -
Sony and Optiarc DVD writers
By anfield7 in forum DVD & Blu-ray WritersReplies: 2Last Post: 1st Oct 2009, 22:44 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 01:52 -
Better DVD Writers
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 13:51 -
Buying 2 SATA DVD Writers
By mis3 in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Aug 2007, 22:08
