i need help on how to copy a dvd to your hard drive without audio sync problems. i use Super dvd ripper but got audio sync problems. THanks
I use DVD Decrypter with no issues. What is the final format you want to save ? DVD, VCD, etc ?
Ripping doesn't cost audio sync issues, just transfers the data from DVD to HD. We need to know exactly what programs, settings and steps you're using to figure out where the problem might be.
I use Smart dVd ripper and i kept all the default settings, yes i am trying to go from DVD to Hd. I tried using the program suggested in the 2nd post but it only goes from DVD to ifo on the HD, I wish to make a DVD go to Hd in mpg format. THANKS!
Audio out of sync when ripping DVD to hq flv
By SystemlordAnubis in forum DVD RippingReplies: 0Last Post: 12th Jan 2011, 06:13 -
AutoGK - ripping the DVD gets out audio out of sync - okay after DVDShrink
By lchiu7 in forum DVD RippingReplies: 7Last Post: 7th Dec 2009, 23:06 -
Off sync audio problems - is it ripping or encoding?
By kirklt in forum DVD RippingReplies: 3Last Post: 14th Jul 2009, 10:48 -
Problems ripping my DVD
By KayAt in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2009, 16:33 -
audio sync problems after ripping dvd
By blubot in forum Video ConversionReplies: 4Last Post: 23rd Sep 2008, 10:14
