When I try to frame-serve with Vdub, the numbers just stay at 0. I have done everything the guidelines have suggested in the event that is doesn't work, too.
Also, when I try to open the file with TMPGEnc Plus, it says it could not locate DRMCLIEN.DLL, EVEN THOUGH I have DLed this DLL and placed it in the directory!
Can someone please help me out?
8) real off the top of my head guess, drmclien.dll something to do with igital rights mgt? windows file type?
I have no clue about the DLL file. I am wondering how to get the whole process to work. I cannot find any info on the DLL. Any further comments?
OK- have you tried any other file to be sure its not the file ?
What kind of file is it, IE; avi, mpeg and what is the codec you are using.
CAn you encode the file in Vdub to another .avi file with no problem ? -
Its not the file. It is an MPEG-2 file. Uncompressed. I want to open it with Virtualdub-MPEG2-AC3 so I can take out the frames I don't want and then frameserve to TMPGEnc to encode that to a seperate MPEG-2 file.
VDub "incompatible data formats" error
By coyote2 in forum EditingReplies: 10Last Post: 1st Nov 2011, 11:28 -
Can't framerserve vdub to tmpgenc under Windows 7 64 bit
By TheFamilyMan in forum Video ConversionReplies: 2Last Post: 8th Nov 2009, 18:29 -
H264 in vdub giving me an error.
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 1st Jul 2009, 09:23 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 31st Jan 2008, 23:24 -
Vdub Mod Error with VOB conversion
By Aaron1927 in forum DVD RippingReplies: 3Last Post: 9th Aug 2007, 12:05
