hey
i downloaded a live Zwan concert video and am having some major issues with it. After about 14 seconds of playing, the video completely freezes, while the audio continues. I tried skipping forward and letting it play for a bit, but nothing changes. The audio moves ahead, but the video stays on the frozen frame from the beginning. After reading the forums for awhile, I tried loading the AVI into virtual dub, and it found no bad frames. Then, I loaded VDub mp3 something or other, which will check for Video Freezes, and it said that there were none, and that all frames where good. I have tried encoding in TMPGenc, but it freezes in exactly the same spot. Lastly, I loaded the file into an AVI fixer (Video Fixer, i believe it was called), and it said that it fixed all errors in my video, but even the new file froze at 14 seconds. If anyone has ANY ideas on how i could salvage this file before I delete it, I would GREATLY appreciate it. I am out of ideas on finding out what is wrong with this video file, and would love some help.
SonnyC79
Results 1 to 9 of 9
Sure. Go back to Virtual Dub. Delete the frame at the spot that causes the freeze. Save the video under a new filename.
Hello. -
hmm...i tried going through and determining which exactly is the frame that causes the problem, and deleted it, but still came up with the video freezing in virtual dub. then, just for the hell of it, i ended up deleting about the first 30 seconds of the video. this gave me a glimmer of hope, in that i was no longer stuck on the same frame as before, but rather a new frame...however, i am still in the same position as before with the video not even playing at all (although on a different frame) and the audio moving ahead. thanks for the super quick reply though. still trying!
Tommyknocker has already advised you to use gSpot - and that's what I'd recommend.
This is because I think this is exactly what happened to me when I tried to play some avi files that were - I think - DivX 5.05, but I only had 5.03 or something on my system.
I updated the DivX codec to ther latest version, and the videos played all the way through fine.
I suspect that's what your problem is.
cheers,
mcdruid. -
hey Druid
IT WORKED! thank you so much...but updating the Divx codec fixed the problem....one thing i noticed though...i may be crazy but i think i notice some static in the sound now that i didnt notice before. any ideas on that one? haha....jk. this will work for me, i'm just glad i can see whats going on. thanks again you guys for your help.
Help with brief video freezes in mpg4 avi
By hibbs in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2010, 19:04 -
AVI Freezes up
By surffx in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2010, 06:49 -
Lots of errors (jumps, gitters, freezes) when authoring a DVD
By DW in forum Authoring (DVD)Replies: 8Last Post: 17th Apr 2009, 10:17 -
Mp4 to avi video freezes in WinFF
By vitamine in forum Video ConversionReplies: 2Last Post: 5th Jan 2009, 23:39 -
CODECS-Too Many? Find and Clean-A/V sync Errors
By mrlewp in forum Software PlayingReplies: 9Last Post: 17th Apr 2008, 06:33
