  1. Help ive decrypted a dvd and when trying to add file in nero vision express it adds 4 vob files but wont add the final 1 yet when i view it in media player it seems fine, any solutions its driving me nuts!
  2. what total size are all of the files you're trying to put on the DVD-R?
    I'm no expert on DVD burning, but I'm pretty sure you need to do more than just decrypt the DVD and then drop the vobs into Nero.
    (I could be wrong - if it's a DVD5, then maybe you don't need to do anything else.)
    Have you looked at the guides for backing up DVD to DVD-R on this site?
    cheers,
    mcdruid.
  3. hi, its a dvd rw that i'm adding to and the vob file is small and even if i try to put it on first without any of the other files it still comes up saying :- unable to insert ...... I have been able to do other dvd's this way.
  4. is the error message any more specifc than that?
  5. So you have ripped the dvd and then you are putting the ripped files onta dvd with no editing ?
    If it's wet, drink it
    My DVD Collection
  6. the error message doesn't say anymore and i cant edit it as it wont load into nero.
