While capturing 320x240 29.97fps avi using VideoStudio 3.0 SE, the audio is fine at first then slowly offsets from the video. Not very noticeable at 3 min. into capture, very noticeable at 7 min.
I'm using a 3dfx 3500TV on a p2-400 with 448MB RAM and an IBM 9.1GB UW scsi Hard Drive if that helps.
Any input would be wonderful.
-wintermute
I recommend using VirtualDub to capture as I do.
Using the "Change audio clock dramatically to match video clock". The audio will say in sync (but you'll one frame every 5 minutes.. good trade to keep the audio in sync, if ya ask me)...
That option is found in the 'Timing' submenu. -
For some reason I can only use the bundled software (VideoStudio 3.0SE) to capture video. All the others that I've tried (MediaStudio6, VirtualDub, AVIEdit) jave resulted in more dropped frames than I can deal with. Sometimes up to 30%. So I'm stuck with VideoStudio3. Unless I've been doing something wrong.
Any suggestions?
-wintermute
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 02:15 -
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 10:19 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 09:31 -
riverpast rm to avi conversion sound out of sync
By princevegetam in forum Video ConversionReplies: 9Last Post: 2nd Jul 2007, 02:45
