Hi all,
I've read here that the Princo Silver/Blue CDR discs will work on my Sony DVP-S360 player, but after I purchased a spindle of these discs, I've found that they do not... At least in my case.
I used CloneCD to copy a VCD (not SVCD) to a Princo CDR, but I get the "NO DISC" message from the Sony. The copy is good, since it will play on my PC.
Anyone with any thoughts besides "you're screwed"?
Thanks![]()
Hi again,
Someone on another thread suggested that maybe the VCD that I copied might not be compliant with my Sony DVP-S360.
Is there a way I can determine if my VCDs are compliant? If so, is there a way to re-author the VCDs which are not compliant to a compliant form?
Thanks for your help. -
Do a search here for your player to see what the specs are plus read the users comments.
https://www.videohelp.com/dvdplayers.php -
I have a sony dvp-s330 and get all my media from here http://www.riskfreedisks.com/ never had any problems, just tell them what you need, they have princo.
Thanks for your responses.
The problem is I bought a spindle of Princos and I copied a VCD (that didn't play on my S360) to a Princo CDR but it still won't play on my S360.
Oddly, I copied a different VCD (that I know plays on my S360) onto a Princo and it does work on my S360.
Someone on another thread pointed out that it might be a VCD compliance issue. How do I re-author the supposedly non-compliant disc to make it compliant?
Thanks again for your suggestions.
My Sony CD/DVD player (NS55P) would almost only play sony discs.
By valdes001 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jan 2011, 11:03 -
Trouble with SONY DVD+R disc and SONY player/recorder
By Winston99 in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2010, 23:54 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2010, 00:56 -
Need DVD Player To Play DVDrs & CDrs
By DJboutit in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Jul 2009, 16:11 -
Sony DVD RW DW-D18a - Won't recognise CD audio/games/CDRs
By knightime in forum DVD & Blu-ray WritersReplies: 3Last Post: 27th Jun 2008, 06:08
