I am hoping that someone here could help me...I just bought the Optorite DD0203 External but for some reason it won't let me install it onto my computer...its says in the book that after I run SETUP.EXE and reboot there should be a new drive disk added...but there isn't...and then it says if this didn't work then I could refer to the Partition to the USB2.0 External Hard Disk chapter...I tried both methods there and either of them worked...can someone please help me?
also...I bought it off of ebay but it doesn't say Optorite anywhere on the box or burner or installation guides...but it did come with all the software that the Optorite supplied...so do I have the Optorite DD0203?
hi Hooo3,
if you goto control panel, system, hardware, device manager, click on dvd/cd-rom drives it should tell you the make and model. mine says optorite dvd rw ddo2o3. your burning software should also tell you the make and model. optionally you can d/l something like dvdinfopro and it will give you all kinds of info on your drive and the burning media it supports. hope this helps. -
Originally Posted by Hooo3
Hooo3
I use nero6 and burnatonce. they both tell me the make of my dvd and cd burner and let me choose which one i'm using.
Synergy wrote "As far as I know, Optorite doesn't sell the external version of DD0203, what you got is just an internal drive plus a third-party external enclosure."
If you got an internal drive like Synergy stated you might be better off to take the burner out of the external enclosure and mount it as an internal drive ie on your second controller. Hope this helps and hope you get it working. Keep us informed to your sucess.
