I have been using NERO to burn my dvd's for a couple of months now and no problems up until last nite that is. I am using the Plextor 504 to burn +R's with and everything has been going fine, I have been burning using udf1.02. I usually burn a disk, then when I finish I put in a new disk , go back to NERO delete the files I moved over into the Video_ts folder, choose a new movie from a new file, hit control A and then burn. But not anymore. Everything in NERO seems to be the same, seems to work the same, just when I try and do more then one disk NERO starts to burn and then just locks my computer up, the dvd burner is still burning but nothing on the dvd. So I turn computer off restart puter remove the coaster I just made relaunch Nero, and no problems the movie comes out fine. So this time I close Nero and then restart it from scratch, get the same thing, my puter locks up. Now the only way I can burn more then one is to close all programs, completely close down windows and then restart and then I am fine, movie plays fine. Nothing has changed on my puter no new programs, no new nothing, just like I all the sudden got gremlins. Is very fustrating, to now have to restart puter after each burn to do another. Anybody have any suggestions.
nero 6 did the same thing to me on both my computers. Lock up and I had to manually restart the computer. I read somewhere that nero INCD caused alot of these problems and to disable it, which I did. This did help but didn't eliminate the problem altogether. I've read from the posts that alot of ppl seem to be having problems with nero 6. From my own personal experience nero 5 seemed to be alot more stable. I also upgraded everytime nero came out with a new upgrade, which didn't seem to help much. I know this doesn't help you very much. but you might want to try disabling INCD. I've also d/l burnatonce at www.burnatonce.com ,which is freeware, and seems to be working good.
Hope this helps.
Going nuts trying to convert a video
By ehunter in forum Video ConversionReplies: 38Last Post: 19th Mar 2010, 10:50 -
DVD Burner going nuts?
By Immortal25 in forum DVD & Blu-ray WritersReplies: 3Last Post: 31st Jan 2009, 10:32 -
Printer driving me nuts
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 27th Dec 2008, 09:47 -
This cdex is driving me NUTS!
By Jo The Veteran in forum AudioReplies: 4Last Post: 18th Oct 2008, 09:26 -
computer going nuts
By jyeh74 in forum Newbie / General discussionsReplies: 33Last Post: 11th Jul 2008, 21:18
