Will the overall video playback improve and not just the gaming side of things? I'm using an onboard video card, 16mb. When I view my DVDs they are somewhat soft or fuzzy, not as sharp as on the TV. I also only have PCI inputs and most cards I see around are AGP. Will that make another difference too as far as video card quality/capabilities?
Results 1 to 16 of 16
It should improve the DVD playback, but you may find it will be just as fuzzy because DVD resolution is lower than the resolution of most PC monitors. They probably seem sharp on TV because TV's work in a different way from monitors.
Yes, a PCI vs AGP card will be another big difference. I believe PCI slots use a frequency of 33MHz and the AGP card uses 66MHz, so a PCI card won't be as fast, but anything better than the onbaord card, with at least 64MB of memory will help a lot. -
what helps is a video card with a good hardware mpeg decoder built in and make sure to enable hardware mpeg playback in your playback app ..
speed of the video card or if its on a pci ir agp buss makes no diff.
case in point -- avid cards, targa 3000's , sdi HD and SD capture and playback cards all work off the pci buss and they have a lot more data transfer"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
PCI video cards suck. Thats why they have AGP cards. 4x 8x PCI runs at 66mhz AGP runs at 66 MHz times 4 or times 8 which equals 264MHZ and 528 MGZ. Gaming and video playback will all dramatically improve. You also need to have a decent processor and a reasonable amount of RAM.
Originally Posted by 808smokey
he was asking about playing back mpeg -- it doesnt mater if it is pci or agp was my point ...
video playback will not change what so ever ... if you have hardware decoding - you dont even need a decent cpu ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
His question was:
When I view my DVDs they are somewhat soft or fuzzy, not as sharp as on the TV.video playback will not change what so ever ...
If not then everyone would have an old pentium 200mhz and never need to upgrade to watch these movies. My friend has a Duron 450mhz and he can barely watch small mpegs let alone a DVD. He uses onboard 16meg video and it sux. It's almost like a slide show.
Yes you can use a PCI card for video but AGP is 10x better than PCI. Besides that most half way decent AGP cards are around the same price as a PCI card. I'd only buy a PCI video card if my mother board didn't support AGP. -
808smokey:
DVD's are mpeg files ....
as for the rest --- i suggest you do up a little study on video playback which i suspect we were doing before you were born ... before you keep putting your foot into it ...
were you also the one who didnt think i could not possabily be using a 64 bit workstation in 1995 (because you believed some marketing crap) and I had to pull out a tonne of data to show you otherwise?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by 808smokey -
I am very surprised your dvds look worse on your screen. I would hazard a guess and say you are using a laptop? no agp, shared 16mb video memory, fuzzy lcd screen ? on my desktop computer screen dvd s look exceptionally sharp and good quality.
A better graphics card may help because they would offer much better 2d performance. Whether that will help with your issue I'm not sure. It might be best to buy a MPEG encoder expansion card (pci), one that would be supported with the software you use. I used to have one and they are great.
Originally Posted by 808smokeyHope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
While we're on the subject are there any mainstream chipsets (Radeon or GeForce) video cards that have hardware decoders?
Radeon , GeForce and matrix parellia and 650 and 750 all have hardware mpeg2 decoders ... ati has HD mpeg decoder hardware though in practise i found that it really plays a max of 15meg/s in hardware then switchs to hardware assist software decoder or software only (for HD) don't know why...
Essentially,
DVD=MPEG
Viewing mpeg2/AVCHD directly from a SD card on a TV
By Ravis in forum Newbie / General discussionsReplies: 5Last Post: 6th May 2010, 13:53 -
Recommendation on a graphics card for .MTS video editing and viewing
By Zetti in forum EditingReplies: 0Last Post: 12th Dec 2009, 23:07 -
Does a better video card improve the quality of video when rendering?
By raysolomon in forum EditingReplies: 8Last Post: 3rd Mar 2009, 20:24 -
Qaulity Capture Card for VHS-DVD & Computer TV Viewing/Capturing
By RubicksCube13 in forum Capturing and VCRReplies: 1Last Post: 11th Nov 2007, 08:00 -
Best PC Video Graphic Card for viewing movies on HDTV???
By hulinning in forum DVB / IPTVReplies: 20Last Post: 16th Oct 2007, 06:04
