  1. Anonymous
    Guest
    Hi all
    Am having the following problem:
    Am trying to encode a DivX to MPEG2 for DVD using the mpeg2enc encoder, and including an .srt subtitle file.
    The movie previews correctly, but when i try to encode, the progress bar never gets beyond the stripey phase and the ffmpegX Progress app gives the following error:
    Current dirname: /usr/local/share/locale
    MPlayer dev-CVS-030316-14:10-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
    : No such file or directory
    AltiVec found
    Reading config file /usr/local/etc/mplayer/mplayer.confReading config file /Users/alex/.mplayer/config
    Reading /Users/alex/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf
    CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm' '-waveheader' '-v' '-osdlevel' '0' '/Users/alex/Desktop/J' 'Renoir_La' 'Regle' 'du' 'Jeu.avi' '-aid' '1' '-sub' '/Users/alex/Desktop/La' 'regle' 'du' 'jeu.srt'
    can't open '/Users/alex/.mplayer/codecs.conf': No such file or directory
    can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
    Can't open input config file /Users/alex/.mplayer/input.conf : No such file or directory
    Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
    Falling back on default (hardcoded) input config
    t/font.desc'
    font: can't open file: /Users/alex/.mplayer/font/font.desc
    Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
    Using Unoptimized OnScreenDisplay
    Using usleep() timing
    Terminal type `unknown' is not defined.
    get_path('input.conf') -> '/Users/alex/.mplayer/input.conf'
    get_path('J.conf') -> '/Users/alex/.mplayer/J.conf'
    File not found: '/Users/alex/Desktop/J'
    Playing /Users/alex/Desktop/J
    Not an URL!
    get_path('Renoir_La.conf') -> '/Users/alex/.mplayer/Renoir_La.conf'
    Playing Renoir_La
    Not an URL!
    get_path('Regle.conf') -> '/Users/alex/.mplayer/Regle.conf'
    Playing Regle
    Not an URL!
    get_path('du.conf') -> '/Users/alex/.mplayer/du.conf'
    Playing du
    Not an URL!
    get_path('Jeu.avi.conf') -> '/Users/alex/.mplayer/Jeu.avi.conf'
    Playing Jeu.avi
    Not an URL!
    get_path('regle.conf') -> '/Users/alex/.mplayer/regle.conf'
    Playing regle
    Not an URL!
    File not found: 'Renoir_La'
    File not found: 'Regle'
    File not found: 'du'
    File not found: 'Jeu.avi'
    File not found: 'regle'
    File not found: 'jeu.srt'
    Playing du
    Not an URL!
    get_path('jeu.srt.conf') -> '/Users/alex/.mplayer/jeu.srt.conf'
    Playing jeu.srt
    Not an URL!
    Exiting... (End of file)
    Have tried moving both the application and the source files to the desktop and other locations but having similar results.
    Any help appreciated
    (Using ffmpegX 0.0.9 and the recommended mencoder and mplayer, which installed without problems.)
    Cheers
  2. Remove all spaces and special characters from your filenames and path names to avoid issues with "Decode with mplayer" process (other processes now accept spaces and special characters).
  3. Anonymous
    Guest
    Thanks major
    much appreciated
