Guys,
Is there anyway I can have a single 500mb MPG file
which is ready for a VCD burn and make multiple chapters
out of it.
I would like the chapters to play without interupption as
on a DVD, breaking the MPG into multiple MPG's and burning as tracks causes a pause between tracks..
How can I either mark tracks in a single large MPG or
burn multiple tracks without the pause?
Cheers
Gary
This can be done for SVCD/MPEG-2 but I am unaware if it is possible to do this for VCD/MPEG-1.
I believe VCDImager is used to make chapters for SVCD/MPEG-2.. not sure... check it out and check if it works for VCD =| -
Both VCD2.0 and SVCD support entrypoints (i.e., chapters). The functionality between VCD2.0 and SVCD in this respect is identical.
Note: these are "entrypoints" not discrete physical "tracks".
If you do a search on "entrypoints" and "vcdimager" on the forum, you will find much more information.
Regards.
Michael Tam
w: Morsels of Evidence -
go to forum AUTHORING AND BURNING. there you'll know how to do it step by step. my question is, when watching dvd movies, do you use these chapters often? if not, then why bother make chapters.
Gadget,
Yeah, sometimes I like to skip to a particular fight
scene or action scene or to skip the credits and stuff like
that..
How to demux .avi file with multiple audio tracks?
By junglemike in forum AudioReplies: 8Last Post: 26th Oct 2012, 18:05 -
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
Multiple clips form a single video file
By ripper316 in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2011, 12:52 -
merge multiple avi to 1 single file
By carlos28355 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Oct 2010, 19:11 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 11:15
