Hi,
I spend quite a bit of time editing holiday videos and now have the intention of putting them onto DVD with lots of "extras" like slideshows etc..
I have done a couple using Studio 8which uses DV Type 2 as the default for editing before conversion but in MSPro7
I can choose between DV Type 1 or Type 2.
There is nothing to say what the difference is but is one more suited for conversion to MPEG2 than the other?
Andrew
Originally Posted by a.wright
Microsoft says - basically - this:
"For video capture, where maximum throughput is crucial, it is better to use a type-1 file, because type-2 files carry redundant audio data."
"(The video stream still has the audio data. The audio is simply hidden by labeling the stream as video.)"
"Also, writing a type-2 file requires some additional processor time to split the interleaved stream."
So...
1. Type 1 requires slightly less processor power because there's only one audio stream.
2. Type 2 requires a little more processing power, but there's a redundant audio stream, which can be helpful when using hardware "real-time" PCI cards.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/directx9_c/directx/ht...pe2dvfiles.asp
Jerry Jones
http://www.jonesgroup.net
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 21:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
type 1 or type 2 capture-newbie
By sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 18:22 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 20:16 -
Convert Type 2 DV to Type 1 (DVdate?)
By nlec in forum Video ConversionReplies: 30Last Post: 30th May 2007, 13:52
