  1. I burn the cd and the only way to see the tracks is by pressing the number of the track. The still photos or the menus donīt work. Any idea?
    Pioneer DVD 626D, Nero 5.5.5.1, VideoCD with Photos and menus.
    Thanks.
  2. does your dvd player play auto when cd is loaded? if yes, press STOP and press play. you'll be able to see your menus hopefully.
  3. Member garman's Avatar
    Sep 2001
    Guantanamo Bay, Cuba
    I believe when you push a number on the remote, pbc is turned off so the cdi info will not display. You must push play to get the pbc to engage. I have a pioneer525 that's how it works for me.
  4. I have done what you told me, with no results. I am using CD-RW. Maybe this is the problem?. In the LCD appears PBC VCD and the screen is blue. I press stop, play ... but until I press the number 1 nothing happens (the movie starts, but i canīt access the menus or the stills).
    I tried both checking and unchecking the "Use CDI application". The names are ISO 9660 Level 1.
    Thanks for the help.
