Hi All,
Hopefully I am using the right forum here, otherwise, apologies! I did do a search of the forums and although similar issues have been noted, no resolutions were provided, so here's to hoping...
I have used AVI2SVCD a few times previously without any errors, however, this morning when I tried to setup a conversion to run while at work, it kept crashing at the BeSweet stage (Windows fault). On the BeSweet tab of AVI2SVCD the only change between this time and previous runs is that the saved directory is a bit longer than previously (talking around 10 characters longer), does anyone know if BeSweet has an issue with file lengths? If not, would any settings on other pages have an influence within BeSweet? Or has anyone experienced/resolved this previously?
Thanks for any advice/suggestions.
Ryan
Results 1 to 1 of 1
Besweet wont encode?
By mrjust in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2010, 22:04 -
besweet, belight
By volam in forum AudioReplies: 0Last Post: 9th Sep 2009, 20:53 -
besweet 5.1 wav
By dvdfreak1971 in forum AudioReplies: 1Last Post: 11th Apr 2008, 14:44 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38
