I have tried time and again but the only way to get it to change to mpg format with sound is using Nero but then the subtitles get cut off. If I load it up into TMPGEnc it works fine until you get to the audio part then it acts like there is no audio at all, whats another program thats easy as TMP and does the same thing, if any?
CCE, MainConcept are 2 other mpeg encoders. But the problem is probably not TMPGEnc, but that your source file has audio in some for TMPGEnc (and possibly even other encoders) strange format.
If you specify the properties of your source file (most notably what codecs are used for audio and video - Use GSpot to get at this info) perhaps someone can direct you.
/Mats
tsMuxeR converts MKV but I have no sound.
By pixiesoft in forum Authoring (Blu-ray)Replies: 4Last Post: 6th Apr 2010, 22:33 -
Hi-Fi sound plops and converts to mono
By Quasipal in forum RestorationReplies: 1Last Post: 20th Feb 2010, 21:43 -
Can't convert one mp4 file, but another from same download converts just fine.
By ibzomie in forum Video ConversionReplies: 1Last Post: 8th Feb 2010, 19:53 -
TMPGEnc Plus converts AVI to MV2 instead of MPEG movie
By buzzsaw in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2009, 19:36 -
WinAvi converts with No Sound
By Yanez in forum Video ConversionReplies: 5Last Post: 12th Sep 2008, 21:12
