There's a GUI for it called rejig.
Allows you to import VOBs, MPEG program streams, and elementary streams. Also has a demuxer. Compression is controlled by a % system.
Quality at 90% is great, 80% is pretty good, much like the other transcoders.
The speed seems to be faster than DVD Shrink. Since it only outputs a .m2v stream, you'll have to remux with the original VOBs. IFOEdit works just fine with this on NTSC streams.
