I have tried this 4 times now, with different movies. And I always get the same bad result.
It stops at the first "Resampling audio from 44.1 KHz to 48 KHz" file.
I never had this problem, until the last upgrade.
I have been running svcd2dvd for more than 4 months now.
Here is the log. I run winXP.
Starting SVCD2DVD: v1.5.1383.35461
Begin time: 20:00:11
******** Ripping SVCD images to get mpegs
Analysing File: F:\encode\bdm_grand1_01.mpg
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Error getting mpeg details. (probably due to AC-3 audio)
Analysing File: F:\encode\bdm_grand2_01.mpg
Analysing File: F:\encode\bdm_grand3_01.mpg
Analysing File: F:\encode\btb_daisy_swe1_01.mpg
Analysing File: F:\encode\btb_daisy_swe2_01.mpg
-->Processing 5 mpeg files.
############### New MPEG File ###############
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
******** Demultipexing original mpg file
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file F:\encode\bdm_grand1_01_DVD.mpv...
File F:\encode\bdm_grand1_01.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 358577
System headers = 1
Padding Stream packets = 5703, total bytes = 8507386
MPEG Audio stream 0 packets = 39694, total bytes = 91018240
Video stream 0 packets = 318881, total bytes = 721062788
Saving stream 0xC0 into file F:\encode\bdm_grand1_01-0.mp2...
Summary:
MPEG Packs = 358577
System headers = 1
******** Resampling audio from 44.1 KHz to 48 KHz
System.ComponentModel.Win32Exception: %1 is not a valid Win32 application
at System.Diagnostics.Process.StartWithCreateProcess( ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at l.d(j A_0)
at l.g()
at l.d(j A_0)
at l.g()
WillsonGuest
Wilson - can you email me to try a few things out?
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Losslees Audio on DVD player without resampling
By ITISRAVI in forum AudioReplies: 7Last Post: 22nd Jun 2011, 23:28 -
Resampling audio
By siluet in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2009, 11:24 -
Resampling Audio
By Germanicus__ in forum AudioReplies: 18Last Post: 19th Jun 2009, 03:55 -
Audio Issues: Resampling, etc.
By tacman1123 in forum ProgrammingReplies: 3Last Post: 21st May 2008, 06:36 -
Audio sync issue even when dynamically resampling audio
By purpleman in forum Capturing and VCRReplies: 4Last Post: 19th Mar 2008, 10:18
