Hi .......
I'm having loads of problems converting an avi file to mpeg for a DVD ....
I'm using TMPGEnc to convert the file .........
It takes AGES to convert (40 hours!) then i get the video, followed by the sound all in one file.
I'm selecting "System+Audio", reducing the file size down to 4070Gb, setting the video to 720x576, 25fps ......
I cab't seem to get it to make the mpeg file into a Video/Audio normal mpeg so i can use DVDit! to author it.
Any ideas?
Dave.
Get yourself a copy of DVD2svcd there is a section of the program that lets you convert AVI to Mpeg 2 for DVD burning.
I've used it takes a little fiddling to get working correctly but when it does takes a fraction of the time TMPGEnc does
http://www.doom9.org/mpg/dvd2svcd.htm[/url] -
What's about the bitrate ... do you use vbr or cb ? Is it possible to get more information ?
dlawedor
In the middle of every difficulty lies opportunity. Albert Einstein
Convert HDTV ts files to DVD mpeg or Avi
By kenmo in forum Video ConversionReplies: 5Last Post: 6th Nov 2011, 09:17 -
Using ffmpeg command line to convert a .vob(DVD) to avi/mpeg
By alfo666 in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2009, 03:14 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Convert AVI to MPEG-4 (asf) for DVD player
By digitalife in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2007, 11:49 -
How do i convert VRO to Avi or MPEG ?
By CoffeehouseSchmuck in forum Newbie / General discussionsReplies: 7Last Post: 10th Sep 2007, 13:56
