Hello all
In the dvdrhelp page it states that encore support DTS-audio. Is this correct or not.
I don't mean encoding, just supporting importing a encoded-dts stream and using it on the dvd.
Anyone any comments on that.
Regards,
RJB
Yes, I believe it does. You can import any type of audio to your project. If it is not DVD compliant it will convert it to PCM or DD 2.0, which ever you choose.
Encore CERTAINLY accepts DTS it says..
Haven't tried it as I'm at loss as to what tool to use to make a DTS file....
How did you make yours? -
If you can host a sample of it somewhere and email me the link I can download it from work and test it and see what it does.
I guess Dolby 5.1 was enough for me since Adobe apps support it pretty well but DTS would be nice to play with sometime. -
Well,
I saw a site that has dts files, maybe you can do a download there and check it out. (I hope you have broadband internet)
regards,
RJB
which video converter that can support DTS-ES (6.1 / 7.1) ???
By roy_harlie in forum Video ConversionReplies: 2Last Post: 4th Feb 2012, 11:35 -
Pls help with my TV USB video problem - does not support dts and subtitle
By emfung in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2011, 05:52 -
True HD/ DTS-MA/HD support for mkv container?
By runLoganrun in forum Blu-ray RippingReplies: 3Last Post: 17th Jan 2009, 09:14 -
MEGUI support for DTS?
By user12345 in forum AudioReplies: 0Last Post: 22nd Dec 2008, 02:03 -
Does this program support DTS?
By jackand7 in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 12:39
